HighDefMike
Link Posted: Wed Jan 04, 2012 3:42 am Post subject: Easier Polarity Adjustment - Provided by SgtVideo on AVSF |
I was bored @ work today, and found this info on AVSForum in the VIP Theater thread; that's been going for quite a while. But since I'm a VIP "johnny-come-lately", I had no idea an easier solution had been provided concerning this.
I'm sure SgtVideo won't mind me posting it over here, in case there's someone else that may not follow/read incredibly long threads that may just contain the very nugget of info they need in a tangent post.
I've made the correction in the post that another poster pointed out following the original posting (replacing DUTY CYCLE with DELAY).
Thanks SgtVideo!
Quote: |
Originally Posted by SgtVideo
Try this alternate method for polarity change:
This technique allows you to change polarity using "Delay".
You can change the polarity via the Dongle on the transmitter. When you are in the Delay (UP & DOWN red lights)... imagine that the five lights are split in two equal halves of L and R. When you go left of the 2.5 settings with the RED lights, you are now configuring a different polarity than if you are extending the red lights to the right beyond the middle point.
Remember you are working with RED lights that change with UP and DOWN movement on the dongle!
L C R
Depending on where you find your best picture setting, you can always find the same setting either to the left of the centre or the right of the centre (c) with the correct polarity. This is the easiest and the fastest way to change the polarity without having to go through the utility or without having to find the “Midas touch” on the dongle to get the centre push right.
