edavi394
Link Posted: Thu Dec 08, 2011 4:08 pm Post subject: looking for a good res to run to my projector. |
Hi, I have a nec xg-110 projector and have it connected to my HTPC. I want to send it the best picture possible but am not sure what resolution i need to go with. I am using a 2.35:1 screen windows 7 and nvidia GTX-460. I have the projector connected with HDMI. Part of my problem is the monitor i am using on my HTPC is a old lcd that is limited to a lower resolution then I want to send to the projector. the projector is in a separate room and I can not see it from the computer. I have tried using the projector as an extension and this does seem to work but it a little bit of a pain to go into full screen mode in a movie since I can not see where to click ect... also then trying to get the player back to the monitor is a real pain. what better solutions are there for doing this? thanks
Link Posted: Thu Dec 08, 2011 4:10 pm Post subject: |
Get a wireless keyboard and mouse to move them into the theater room.
If your focusing on the XG is razor sharp, then 1080p shouldn't be an issue. Some XGs are always a bit out in the corners, and if that's the case with yours, I'd run 720p.
edavi394
Link Posted: Thu Dec 08, 2011 4:26 pm Post subject: |
I thought about the wireless key board and mouse I have a set actually, but 2 things I was not sure about. 1 I don't know if the range is going to be good enough but this i can test. but the other thing is I will be in the same situation I am not right? I will only be ably to see what is on the projector but my desktop ect will be on the monitor... I guess I could go in the computer room and put the video on the projector then go in and adjust that.. just thought there would be something more more simple.
edavi394
Link Posted: Thu Dec 08, 2011 5:14 pm Post subject: |
Awesome thanks!
Link Posted: Thu Dec 08, 2011 5:45 pm Post subject: |
You could try cloning your desktop but then you may be limited to the resolution of your LCD monitor. Some graphics cards will allow two separate resolutions for monitor A ( LCD) and monitor B ( NEC PJ ).
edavi394
Link Posted: Thu Dec 08, 2011 5:58 pm Post subject: |
yeah for cloning I am limited to a lower resolution plus the lcd monitor is a 4:3 any good software for playing blu-ray movies? I have a blu-ray drive in the pc and was going to rent a movie to test it out ( i currently own no blu-ray's but do own around 500 dvd's )
Link Posted: Fri Dec 09, 2011 5:40 am Post subject: |
I like 1440 x 960 @ 72Hz for DVD or even 1024x768 @72Hz as a general use resolution for desktop and DVD.
1080i@72 for bluray.
Somebody else will have to advise you one Bluray software.
Go get your self a CRT monitor 17-21" like a 17" Samsung 753 ( that will do 1080p! ) or one of the Sony's or Sony clones ( HP, SG, LaCie etc ) it makes life so much easier. Most will do 1080p except the low end ones. It's great for setting up resolutions. I use a Sony G520P 21" and the Samsung 17" as well as a Viewsonic 17" P series
prover
Joined: 07 Nov 2008 Posts: 166 Location: Stuttgart, Germany
Link Posted: Fri Dec 09, 2011 2:04 pm Post subject: |
edavi394 wrote: | yeah for cloning I am limited to a lower resolution plus the lcd monitor is a 4:3 any good software for playing blu-ray movies? I have a blu-ray drive in the pc and was going to rent a movie to test it out ( i currently own no blu-ray's but do own around 500 dvd's ) |
I use PowerDVD10 Ultra 3D MarkII, works great under Win7.
_________________ http://www.bluray-disc.de/blulife/heimkino/prover
