Recommendations for a new HTPC
Goto page Previous  1, 2, 3 ... 14, 15, 16
greg_mitch
PostLink    Posted: Tue Oct 04, 2011 3:13 am    Post subject: Reply with quote
Wait...why don't you like the 2250? Are you saying that it can't record one analog and one digital at the same time? I guess I haven't tried that yet but I also have an HDHomerun so I can never tell which HD tuner I am watching in 7MC.
I still have some PVR 150's sitting around here somewhere...those bring back memories.
PostLink    Posted: Tue Oct 04, 2011 3:19 am    Post subject: Reply with quote
Yes that's exactly what I am saying about the 2250. It only has ONE co-axial input. So if you plug in the ATSC antenna you can only do 2x digital.
Although it would do analog/digital if you cable system broadcasts QAM in the clear digital channels, because you would only require one co-axial cable
I actually didn't mean to post that picture of the 150's BTW wrong file number Laughing
PostLink    Posted: Tue Nov 15, 2011 8:19 am    Post subject: Reply with quote
Currently running 2 hauppauge cards. A 1600 PCI and an 1850 PCIe 1x. 4 tuners, dead reliable. I like it!
PostLink    Posted: Wed Oct 10, 2012 10:01 am    Post subject: Reply with quote
Wow it sure doesn't take long to fill 1.8TB (So called 2TB lies) hard drives with this machine. Gone through 2 and need another. Also addded a Bluray burner. Very handy.
PostLink    Posted: Sun Dec 09, 2012 11:20 am    Post subject: Reply with quote
On 1.8TB Drive number 3, also miss placed my 500gb drive. Damn, it has the last season of Chuck on it too.
This box just keeps hummin' along.
PostLink    Posted: Wed Nov 27, 2013 5:41 pm    Post subject: Reply with quote
On 1.8TB drive #5, the analog channels are going away slowly here so i may have to get two of those useless cable TV boxes by Cisco just to get back to where I was 7 years ago. Yeah, digital cable really great Thumbs Down
PostLink    Posted: Fri Apr 17, 2015 4:15 pm    Post subject: Reply with quote
On 1.8TB drive number 8, tried hooking up the cable box using the IR blaster that's plugged into the Hauppauge 1800 card. Won't work in a system with two capture cards! PITA!
For now, just recording ATSC.
Also added the Homerun HD tuner v.1 that Greg was talking about above, -the actual- tuner that was Greg's. I bought it off him and didn't even realize his post was here Laughing
Won't work in Win7 but works great in Mythuntu linux. Mythuntu actually found it and launched the tuner application. Can't tune the sub channels though. No matter. Just bought it to play with.
My point is this HTPC is still humming along.
...and I needed to bump this post so I could find it. Wink
PostLink    Posted: Fri Apr 17, 2015 4:49 pm    Post subject: Reply with quote
Also will be playing with blending using the spare parts from this build and a Quadro card. See here: http://www.curtpalme.com/forum/viewtopic.php?t=37855
I'm also looking for one of the ATi AIW-3650-HD cards should be around $30 now. Also looking for the ATI All-In-Wonder HD Accessory Kit with the Composite/S-video/Component input to go with it. Should be fun to play with.
Resurrect the old PC's and put them to use.
EDIT: Composite/S-video in Component OUT Sad
PostLink    Posted: Wed Oct 18, 2017 4:13 am    Post subject: Reply with quote
Trouble- the system is down! No boot! Stay tuned!
PostLink    Posted: Fri Oct 19, 2018 3:21 am    Post subject: Reply with quote
Too funny, almost a year to the day...
Booted it after not using it for 4 months or so, Windoze XP froze, I took it apart, changed the 120mm fan, cleaned the dust out. Changed the BIOS battery and restored the BIOS on the dual BIOS motherboard. Booted it up, and am now doing a test recording.
Just a litte maintinence.
PostLink    Posted: Fri Oct 26, 2018 3:46 am    Post subject: Reply with quote
I just booted a Windows 2000 computer that had not been turned on in over a decade. I can't believe it worked.
PostLink    Posted: Fri Oct 26, 2018 3:56 am    Post subject: Reply with quote
My 8-yr-old laptop (that I've hauled around the country for 70-80 weeks of business trips and another 10-15 weeks of family visits) was getting a bit noisy -- cooling fan obviously going. I was hoping it would hang in there until I got a new laptop Real Soon. Well it didn't. Got a new fan, and of course the fan is buried deep in the belly of the beast hooked up to heatsinks &etc, but I got it replaced. But now the laptop won't boot normally. I can boot into Safe Mode, but even a Clean Boot (all services/etc disabled) doesn't work. It displays the blue-window boot screen, but the little spinny-circle thingie either runs forever until it gives up and goes into a troubleshooting menu, or it just freezes up. I've tried everything I can think of, including doing a complete image-backup restore. No joy. Sad
PostLink    Posted: Fri Oct 26, 2018 5:20 am    Post subject: Reply with quote
Since they folded the TV spectrum and cut the TV channels in half this box is having trouble recording. I may have to repurpose it to XP gaming again. Either that or pick up a 4 tuner hauppauge card and win7 Pro and a new hard drive.......
Gary I feel your pain. I had an HP here with a bad fan, bad DVD slot, bad/intermittant touch pad and a hell of a booting issue.
PostLink    Posted: Thu Nov 01, 2018 3:28 am    Post subject: Reply with quote
Gary I have had luck buying used laptops off ebay. I go for high end laptopsl like a Dell Latitude. I found the trick is to buy one without a hard drive. I realize buying Windows is an added cost along with a new hard drive. Fortunately I don't use Windows.
PostLink    Posted: Thu Nov 01, 2018 4:07 pm    Post subject: Reply with quote
Oh I have a sexy new (refurb) laptop on its way (HP Spectre x360 15", 16GB RAM, 512GB SSD). I just wanted to resurrect the old beast because it has some legacy apps that I won't be able to replicate on the new laptop. Plus I hate to throw something away if I can fix it, something many in this group will understand. Very Happy
PostLink    Posted: Fri Nov 02, 2018 2:13 am    Post subject: Reply with quote
Nope can't relate. Not at all, Laughing
PostLink    Posted: Thu Oct 10, 2019 3:35 am    Post subject: Reply with quote
Posted: Mon Oct 03, 2011 10:19 pm
Just re-installed this card as the other two were acting up. Also put the Auzen Tech Xmeridian back in. Found the manual and driver disk beside the HTPC - right where I left it in 2008 Smile
PostLink    Posted: Sat Feb 08, 2020 9:28 am    Post subject: Reply with quote
I just noticed this topic has been viewed 134078 times! AWEsome!
Page 16 of 16
