Marquee 8000 Won't Power On
ksevksev
PostLink    Posted: Wed Feb 09, 2011 8:30 pm    Post subject: Marquee 8000 Won't Power On Reply with quote
I've been using my Marquee 8000 (mounted my ceiling) for several years now with minimal trouble. Recently though, it will not power on. When I plug in the projector, I hear the fan (I'm guessing this is the LVPS based on some reads of this forum). When I attempt to power on the projector, I can see the diag light indicating that it is receiving the IR signal, but it won't turn on.
Any ideas, on where to start?
I recently upgraded to Blu-ray and added an HDFury to improve the picture, so I'm really missing my proj! Thanks in advance!
PostLink    Posted: Wed Feb 09, 2011 8:37 pm    Post subject: Reply with quote
Reseat the HDM( Horizontal Deflection module)
PostLink    Posted: Wed Feb 09, 2011 9:18 pm    Post subject: Reply with quote
Check to see if there are any red error lights on the main LVPS (red lights are behind the front panel) and make sure there are no error lights on the CLM at the back.
Sparky015
PostLink    Posted: Thu Feb 10, 2011 2:52 am    Post subject: Reply with quote
If the remote is not hard-wired, replace the batteries. Even if the C light is blinking, if the batteries are critically low it will make the PJ do funky things like not turn on.
~Paul
JustGreg
TV/Projector: Marquee 8500
PostLink    Posted: Thu Feb 10, 2011 9:36 am    Post subject: Reply with quote
It sounds like you're also waaaay past due for a good cleaning; chips, sockets, plugs, card edges, etc. There's tons of references on how to do that here, at AVS, and Googling if you've never done it before.
Greg
ksevksev
PostLink    Posted: Tue Feb 22, 2011 5:22 am    Post subject: Thanks for the help, but I'm not there yet. Reply with quote
Okay, my timing is likely revealing the fact, that I have a wife and several kids and have a hard time getting around to my hobbies. I don't regret it, I'm sure the time invested in the family will yielded infinitely more rewards, than tinkering with a PJ. But, I do love movies, so I squeeze it in when I can.
First, thanks for all the hints at where to start. Though I have some technical acumen, I'm new to CRT's. The most I've done so far is mounting, setup, and replace a board at the back that went bad. I started reading the Marquee 8000 tips here and I'll finish that next chance I get.
Of course the hardest thing was getting it off my ceiling without dropping/breaking the PJ or injuring/killing anyone. I have it conveniently positioned on a furniture moving dolly. Now I can easily move it where I need it and move it under the ping pong table when I'm not working on it. This is working great for me, so I recommend it. However, I'm open to better ideas.
What I've done so far:
* Started reading the tips.
* I reseated the HDM( Horizontal Deflection module) several times as suggested here and in the tips.
* Replaced the remote batteries.
Status:
* No error lights on the back of the CLM. I'm just seeing the Standby light and the I/R indicator flickers when I hold down remote buttons.
* Still no power.
* I haven't got to the LVPS yet to see the error lights there.
Plans:
* Dig up a full cleaning procedure and do it while the beast is on the floor.
* Complete reading the Marquee tips here.
* Try fixing anything that the tips say can cause this condition.
* Hope for more brilliant suggestions.
In the meantime:
* What would it cost to get this early model Marquee 8000 modded out to 8500 standards and handling 1080p with ease?
* Is that even an option?
* I need a 9' HDMI cable and I'm looking at blue jean. Is the best place to look?
Thanks again!
Ken
PostLink    Posted: Tue Feb 22, 2011 6:30 pm    Post subject: Reply with quote
Hello
OK you are seeing an orange Ready Light so your AC power is likely okay. Are you holding the Power button down for 2-3 seconds? Are you seeing a green On led? Is the C red led flashing on the rear panel? If you are using an IR keypad have you tried new batteries?
ksevksev
PostLink    Posted: Tue Feb 22, 2011 8:06 pm    Post subject: Reply to Tim in Phoenix Reply with quote
Tim,
* The remote batteries are fresh.
* I am holding down the power button for a long time. That did get me the first time I used it, but I'm over the power-up delay now.
* I'm not seeing the green power up led on the back of the CLM.
Thanks,
Ken
PostLink    Posted: Tue Feb 22, 2011 9:40 pm    Post subject: Re: Thanks for the help, but I'm not there yet. Reply with quote
ksevksev wrote:
In the meantime:
* Is that even an option?Thanks again!
Ken
sure it's possible, for an old 8500 you can simply buy one off e-bay and swap all the boards over. You'll have to deal with freight though. If you want re-furbishd/modifed high performance parts then it's more.
On your machine, good chance the high voltage power supply died, not un-common on the older machines.
dmarnold
PostLink    Posted: Tue Mar 01, 2011 5:14 am    Post subject: hey Tim Reply with quote
You asked if the red "c" light was flashing?
I'm having a similar problem but i do get the green "power" light, flashing "c" light when using remote, but still no power up on the tubes. Haven't removed the LVPS panel to check red lights. Is that my next step?
Sorry to be a pain.....
enjoy today, for change is on the way
HK-Steve
PostLink    Posted: Tue Mar 01, 2011 9:58 am    Post subject: Reply with quote
Maybe it is time to strip down the projector and check the belly fans, Possibly 1 has stopped working.
Cheers
Steve
PostLink    Posted: Tue Mar 01, 2011 4:07 pm    Post subject: Re: hey Tim Reply with quote
you don't remove the LVPS to check it, simply look through the front cover-panel slots with power applied.
the_avguy
PostLink    Posted: Tue Mar 01, 2011 11:28 pm    Post subject: Reply with quote
Cheers
Steve
Will the projector stop working if one of the fans dies?
It makes sense as you wouldn't want it to overheat and it is probably in a manual somewhere but ....
working ECP 4100.
marquee still in pieces, just gathering knowledge.
Nec PJ6000EN, I seem to be getting dumber not smarter.
dmarnold
PostLink    Posted: Wed Mar 02, 2011 1:01 am    Post subject: Reply with quote
belly fans?
ok i see 'em in my exploded view...
they can be accessed through the bottom without all the disassembly......removing access plate....
also, no LVPS red lights visible through front panel slots with green power light on and fans running...????
dmarnold
PostLink    Posted: Wed Mar 02, 2011 1:22 am    Post subject: Reply with quote
with green power light on, all 3 belly fans run, no errors on control module, but alas, no high voltage crackle Sad
any hints guys?
HK-Steve
PostLink    Posted: Wed Mar 02, 2011 11:56 am    Post subject: Reply with quote
Ken,
Do you have any spare boards to change over?
For me, I would start with the basics,
remove the HDM, - Horizontal,
remove the FCM, - Focus,
unplug the VNB's x3,
unplug the 2x connectors to the rear heatsink Convergence, Vertical boards.
Take the HVPS out.
Then see it the projector runs.
You should get a green led on the control board, the belly fans will run. If not let us know.
If it runs, then put the FCM, Focus board back in and connect focus coils. See if it runs.
If it runs then put the HDM, Horizontal board back in and connect deflection coils. See if it runs.
Continue with the VNB's one at a time. See if it runs.
then continue with the Convergence connector, make sure to connect the convergence coils, otherwise you will cook it. See if it runs.
then contiune with the vertical board connector and plug vertical coils in. See if it runs.
Last would be the HVPS, installed and connected to each tube and splitter.
Let us know how it goes and at what stage nothing happens.
Just a thought after writing all these steps,
be sure the insulation strip is installed on the edge of the heatsink at the connector edge, so no shorts to the chassis.
Cheers
Steve
HK-Steve
PostLink    Posted: Wed Mar 02, 2011 11:59 am    Post subject: Reply with quote
dmarnold
Sounds like a HDM to me, Horizontal board.
I would install a test unit, or borrow if you can.
If not Curt can do a good deal on one.
Cheers
Steve
PostLink    Posted: Wed Mar 02, 2011 6:15 pm    Post subject: Reply with quote
HK-Steve wrote:
dmarnold
the HDM will normally put up an error light on the CLM, not always but usually it will. Considering it's an older 8000 my first suspect would be hte high voltage power supply, then the HDM, then possibly one of the neck-boards. The ones with the metal cans were much more senstive to static discharge from the tube bell.
Arnold the easiest thing to do is to take all the above parts and maybe a couple more and send them to someone who can test them in a working chassis. Shipping one board at a time back and forth is very time consuming and expensive.
