jonathan
johnsmith808
Link Posted: Fri Jan 28, 2011 8:04 pm Post subject: |
Jonathan,
You folks seem to be working faster than the other companies making these adapters. Not sure if it's because they are larger companies, but for whatever reason, they are just dragging their feet. It's refreshing to see a company get things done in a timely fashion. Thanks for your efforts!
Quick question on the 3D-Displayer: Will it be able to play xbox360 3d games?
Holmquist
Link Posted: Mon Jan 31, 2011 6:25 am Post subject: |
I'm a little confused as to how exactly this device will work with my current set up. The description says that it will work with any DLP projector or TV that has 120hrz refresh rate. But also the projector/TV must be "3D ready" so that it has DLP link correct? Other wise there is no way of syncing the glases to the alternating frames. So for example with my current setup which utilizes an Optoma HD70 "a 720p DLP 120hrz refresh rate projector" I would not be able to use the 3D gamer because it is not a "3D ready" projector and hence does not have DLP link to sync the glasses to the alternating frames. Can someone please enlighten me as to wether or not what im saying is correct or not. Thank you very much for info you may be able to provide me with.
Austin
_________________ Take care, stay in the air.
jonathan
Link Posted: Mon Jan 31, 2011 3:52 pm Post subject: |
We checked and your HD70 is indeed 120Hz capable but it isn't 3d-ready (no DLP-link capability) so it seems you will need the displayer because the need for the external emitter. Gamer will not work with your projector as it does not have an external emitter connection.
_________________ Watch 3D movies and play 3D games on your TV/projector!
wall11ll
Link Posted: Mon Jan 31, 2011 6:03 pm Post subject: |
hello i pre ordered the 3d gamer and not recieved any email or confirmation of delivery it has been 7 days since the products release and im in 3d purgatory with info saying orders will be complete by the forth, well normal shipping takes 3 to 5 days so my comfirmation should be here today or tomorrow not trying to hassle but just want some info on my particular shipping date
Joined: 06 Mar 2006 Posts: 12404 Location: Ottawa, Canada
Link Posted: Mon Jan 31, 2011 6:41 pm Post subject: |
| wall11ll wrote: | | hello i pre ordered the 3d gamer and not recieved any email or confirmation of delivery it has been 7 days since the products release and im in 3d purgatory with info saying orders will be complete by the forth, well normal shipping takes 3 to 5 days so my comfirmation should be here today or tomorrow not trying to hassle but just want some info on my particular shipping date |
I believe you've also emailed us which is the right thing to do as we have no idea who people are based on the screen names used here.
Any questions about orders should be sent to 3d-vip@curtpalme.com with information on your order. Forwarding your payment confirmation is typically the best way as we see who you are.
As for your order (assuming I've got the right person here), we've emailed you back too as we have no records of anyone with your name having pre-ordered. Please check your emails.
wall11ll
Link Posted: Mon Jan 31, 2011 7:03 pm Post subject: |
fast reply, good customer service!
defiancecp
Link Posted: Thu Feb 03, 2011 12:24 am Post subject: |
Just got mine in today! I posted this review over at AVSForums, but figured it would be of use here too
So I got it in, connected it inline between my receiver (hdmi 1.4) and my projector (pro350w, same thing as hd66 basically). Started up the PS3, went to display configuration, did the auto-config, it recognized it as 3d. Yay!
Time for some gran turismo 5!
I didn't have quite a trouble-free setup, but that was my fault - turns out some of my supposedly high-speed hdmi cables were not - so I kept getting dropouts. But when I replaced the cable from the PS3 to the receiver, done, no problems anymore.
Gran turismo 5 in 3d is pretty amazing, and I can't wait to try vudu.
Also, I went a step further in testing - My HTPC works perfectly through it! Woohoo! What that means is, just like that, I now have a simple "change the receiver" theater again, for the first time since I started dabbling in 3d! MAN you don't realize how cool it is to finally be there! I can be playing PS3 in 2d, switch to a 3d game, then press 1 button on my remote and be at my PC desktop, then into a 3d game, all with trueHD audio. Compared to the mass of wires and switching I had to do before (since my projector won't carry 120hz video), this is AWESOME
The configuration is:
Sources (PS3/HTPC) -> HDMI 1.4 receiver -> 3d-gamer -> projector (pro350w)
The htpc is outputting from an ATI 6870, and it was shockingly easy to configure. The ATI card recognized it as 3d right off the bat, and the first test worked. I was expecting trouble from two things; I'd heard people say that the ATI drivers had issues enabling 3d with receivers in the chain, and the ATI drivers supposedly don't automatically enable unless they recognize the edid... I thought there would be no way it would recognize this since it was so new, but it did, and no issues with audio via the receiver either.
The receiver is a Pioneer VSX-520-K
So in the end, I got almost as much benefit from being able to put my htpc through my receiver as I did from PS3 compatibility
Anyway, I'd score this little guy 100%. Awesome product.
defiancecp
Link Posted: Thu Feb 03, 2011 12:58 am Post subject: |
HA! I *KNEW* I could find something to whine about
The device is detected as being 1080p compatible, so default resolution for 2d games is now 1080p... The only way I know to make the ps3 default to 720p is by using manual display configuration, which doesn't allow 3d options to work...
So now the projector's going to be scaling, right?
Is there any way to tell my PS3 not to output 1080p for 2d games?
If not, as a suggestion for potential improvement, I'd suggest it not report itself capable of 1080p at all, that way my PS3 will still output 720p for my 2d games instead of 1080p.
Cube
Link Posted: Thu Feb 03, 2011 1:43 am Post subject: |
Yeah, I was wondering about that. They should have DIP switches or something so you can set it to report only 720p compatible, etc. PS3 should give you more manual control over this.
However, you don't have to worry about it in practice. Most PS3 games, 3D or not, output in 720p regardless of your settings and won't be upscaled. Most if not all 3D games will be 720p-only due to the increased processing demands. So, if your projector can't do 1080p for the rare games that support it, just manually change the output settings to 720p/non-3D before you play.
I think the bigger problem would be that if your output settings include 1080p the XMB (PS3 main menu) will display in that resolution, so you might have to navigate blindly or something until your 720p game starts. How is that on your projector?
defiancecp
Link Posted: Thu Feb 03, 2011 2:37 am Post subject: |
Well, displaying 1080p in the menus isn't a problem for me; my projector accepts it and scales it to 720p. My concern is that scaling leads to lag, so if a game is running in 1080p, there could be lag issues caused. But maybe that's not a problem, I don't know of any games I have that run in 1080p now that I think about it. For some reason I thought some did, but now that I've tried a few I guess not
gravy
Link Posted: Thu Feb 03, 2011 9:30 pm Post subject: |
The 3D Gamer is awesome. I also have it inline, after the output of my receiver. That goes into a matrix switch, so i can send any signal to either projector or TV. The device doesn't seem to get in the way, and always activates when the PS3 wants 3D. I've played 3D movies from the PSN Store, and 3D content from VUDU. All games have worked without issue.
I agree with the above poster that only the rare game is 1080p, and the PS3 makes it quick & easy to disable resolutions, and re-setup later for 3D if needed.
jonathan
Link Posted: Fri Feb 04, 2011 3:56 am Post subject: |
We have shipped all 3D-gamer pre-orders except some of the ones with additional glasses. Due to Chinese new-year holiday our shipment is being delayed and therefore we have to wait a few more days before shipping those orders out. Everything should clear by mid next week.
AndyKoopa
Link Posted: Fri Feb 04, 2011 1:06 pm Post subject: |
Will this work on my Mitsubishi WD-73833? I have the Mitsubishi 3d adapter and it works great for 3D Movies but the games are upconverted to 1080p and they look stretched. This looks like it will solve my problems but I just want to make sure
xrubiras
Link Posted: Fri Feb 04, 2011 5:20 pm Post subject: |
Hello Ka!
I would like if the 3D-THEATRE CONVERTER will works with side by side 3d movies. I have many 1080p side by side movies, a media player, an Optoma DW318 3D ready proyector and DLP LINK glasses.
What is the intended release date for the 3D-THEATRE CONVERTER?
Thank you.
johnsmith808
Link Posted: Sat Feb 05, 2011 6:13 pm Post subject: |
So does this output everything at 720p120hz, including non 3d content?
defiancecp
Link Posted: Sun Feb 06, 2011 3:45 pm Post subject: |
No, non-3d content passes through at whatever resolution is sent, only 3d 720p frame packed content is converted.
Cube
Link Posted: Mon Feb 07, 2011 12:45 am Post subject: |
Is there any way to get a North American PS3 to output 720p100?
johnsmith808
Link Posted: Mon Feb 07, 2011 9:44 am Post subject: |
| defiancecp wrote: | | No, non-3d content passes through at whatever resolution is sent, only 3d 720p frame packed content is converted. |
Okay, so will the higher versions, such as 3d displayer be able to output 120hz from a 24hz or 60hz source in 2d? Or is an htpc the only way to get 120hz in 2d?
jonathan
