All about lenses (specs/datasheets/pictures/etc.)
Goto page 1, 2, 3 ... 10, 11, 12  Next
PostLink    Posted: Tue Nov 14, 2006 2:17 am    Post subject: All about lenses (specs/datasheets/pictures/etc.) Reply with quote
I started this thread to round up the documents and photos of different lens types many may have on hand or stashed away in their computers .
Copied from Barco.com :
Standard Lens
HD8:
Screen width from 4.6 ft./1.4 m up to 19.6 ft./6 m
Optical resolution 10 line pairs/mm 1600 x 1250 ANSI pixels
HD-8 specs :
http://rennfast.dns2go.com/Public/CRT-Projectors/Electrohome/Lenses/HD8B%20drawing.pdf
Optional lenses
HD117-12:
Screen width from 2.0 ft./0.6 m up to 5.0 ft./1.53 m
HD117-24:
Screen width from 5.0 ft./1.53 m up to 22.3 ft./6.8 m
HRQ 804:
radius: 9.8-16.4 ft./3-5m
3M WHITE PAPERS link . 41 page PDF file 3M paper on optical lens design .
http://web.archive.org/web/20050426195122/http://cms.3m.com/cms/US/en/0-78/ceiuzFA/viewimage.jhtml
3M lenses link ...
http://CMS.3m.com/cms/US/en/2-187/kkrcFFR/view.jhtml
Getting this info on the HD-144's was like pulling teeth ... Wink
HD-144 pdf 1.pdf
 Filename:  HD-144 pdf 1.pdf
 Filesize:  1.35 MB
 Downloaded:  1242 Time(s)
HD-144 pdf 1.pdf
 Filesize:  1.35 MB
 Downloaded:  1465 Time(s)
10L-GT-17-GT26 lenses.doc
 Filename:  10L-GT-17-GT26 lenses.doc
 Filesize:  34 KB
 Downloaded:  1620 Time(s)
PostLink    Posted: Tue Nov 14, 2006 2:21 am    Post subject: Reply with quote
The Barco series of LC lenses consist of the following :
The HD-120 = The HD-10GT17
The HD-180 = The HD-10GT26
And I believe ...
The HD-300 = The HD-10L
PostLink    Posted: Tue Nov 14, 2006 4:06 am    Post subject: Reply with quote
A nice read borrowed from site B on various lenses using the torus screen . Wink
http://www.avsforum.com/avs-vb/archive/index.php/t-517113.html
And no ads
Twisted Evil
PostLink    Posted: Tue Nov 14, 2006 5:41 am    Post subject: Reply with quote
The HFQ-900 that is made for Barco is reportedly a lens that is intended to give the high performance of the GT17 (resolution of 12 line pairs/mm) over a larger array of screen sizes. It can take the place of the GT17, the HD-10L, and HD-10E all by itself.
The standard HD-10 has a resolution rating of 10 line pairs/mm. I believe this is also
the rated resolution of the HD-10L and HD-10E, which are optimized for different screen sizes and throw distances.
CJ
PostLink    Posted: Tue Nov 14, 2006 5:53 am    Post subject: Reply with quote
HD-10 family specs..
hd10_specs.pdf
 Filename:  hd10_specs.pdf
 Filesize:  41.39 KB
 Downloaded:  1928 Time(s)
PostLink    Posted: Tue Nov 14, 2006 5:59 am    Post subject: Reply with quote
This stuff needs to make it to the main site. I needed this about a month ago in the worst way..Smile
PostLink    Posted: Tue Nov 14, 2006 6:00 am    Post subject: Reply with quote
HD-8 specs.
http://rennfast.dns2go.com/Public/CRT-Projectors/Electrohome/Lenses/HD8B%20Specs.pdf
PostLink    Posted: Tue Nov 14, 2006 6:10 am    Post subject: Reply with quote
HD-145 specs .
http://rennfast.dns2go.com/Public/CRT-Projectors/Electrohome/Lenses/HD145%20Specs.pdf
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 10:43 am    Post subject: Reply with quote
Tom thanks, I always meant to do a Lens and a tube thread..........
(Tube thread I started on AVS its a start.....)
I will post some Lens pictures I have.
HD8 came in the following versions
HD8 - original Aliminium case, some glass elements ???
HD8 RevB - RARE - Aliminium housing, Newer plastic elements
HD8 RevB - Plastic housing - most common lens - more plastic elements i think ???
HD8 RevB - COLOUR FILTERED - MEGA RARE !!!
There was as always a "change over point" in the lens builds........
Between the Original HD8 and the Plastic HD8 RevB there were a number of original Aliminium Housings with the revB lens set.
The ONE lens that I have has BOTH stickers on it.......
Older lens types have the metal butterfly nuts, newer have the plastic nuts.
Im off to take some photos.......
(Kals gonna be busy!)
Usually I try and write color/colour and Aliminium/Aluminum - there are gonna be so many in this thread you just gotta go with what I write !
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 10:48 am    Post subject: Reply with quote
HD6C ML (Direct replacement fitting for Tac3,Tac4,HD144,HD145,HD6)
These are the colour filtered versions
NOTE the additional "coloured" label as well as the standard silver one.
HD6C ML - Blue close up
 Filesize:  28.07 KB
 Viewed:  61612 Time(s)
Set of 3 HD6C ML
 Filesize:  20.89 KB
 Viewed:  61607 Time(s)
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 10:53 am    Post subject: Reply with quote
HD 145 - Colour Filtered Set - NOT ALL 144 and 145 are colour filtered.
You can tell by the obvious colour looking through the lens BUT also the Lens Label for green and red is Green or Red instead of the normal Silver.
HD 145 Green Colour Filtered Label
 Filesize:  22.6 KB
 Viewed:  61605 Time(s)
Set HD 145 Colour Filtered Front View
 Filesize:  15.68 KB
 Filesize:  19.21 KB
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 10:58 am    Post subject: Reply with quote
HD10 GT17 also called HD120 by Barco
HD10 GT17
 Filesize:  18.55 KB
 Viewed:  61598 Time(s)
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 11:18 am    Post subject: Reply with quote
Match the word to the picture please.........the pictures appear in reverse order.........
Sony 1292 and G90 use a HD10F - this is sometimes thought to be a HFQ900 - this is NOT confirmed.
However Barco call the Lens a HFQ900
I am under the understanding that these are "based" around an HD10E lens BUT have better edge focus and so "might" be hand picked with the tightest tolerance, or have a "special" outer focus system.
NOTE the HFQ900 has a platic front section on the Aliminium main body.
To colour filter these "Liquid Coupled" "LC" lens types you use a colour filtered "Critical" "C" Element
HD10L used for small screens in practice on a 1209s best suited to 4-6 foot wide screens
HD10GT17 / HD120 in practice on a 1209s best suited to 6 to 10 foot wide screens.
Sony HD10F
 Filesize:  24.2 KB
 Viewed:  61595 Time(s)
HD10L
 Filesize:  16.46 KB
Colour filtered Critical Element
 Filesize:  23.4 KB
Newer HFQ900
 Filesize:  20.62 KB
 Viewed:  61597 Time(s)
Cine9 with 3xHFQ900 - nice
 Filesize:  30.1 KB
 Viewed:  61594 Time(s)
Early HFQ900 all alimiunium
 Filesize:  22.41 KB
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 11:36 am    Post subject: Reply with quote
HD 8 pictures
Old original Aliminium Housing - MUCH more stable and LESS drift through Temp change, reported Better edge focus on the older lens types.
NOTE the plastic housing and Black plastic knobs on the newer versions
RARE HD8 RevB in a Aliminium housing - the original HD8 Label is underneath! this to "ME" proves the use of both new and old parts in a change over time - there are VERY FEW of these !!! I have ONE, not one set!
Rarest of course the HD8 Colour Filtered , fitted to Cine8 Onyx as I understand (maybe others)
HD8 RevB Label
 Filesize:  35.68 KB
 Viewed:  61592 Time(s)
HD8 OLD Housing
 Filesize:  18.06 KB
HD8 NEW Housing
 Filesize:  24.39 KB
 Viewed:  61591 Time(s)
HD8 RevB in Original Housing RARE
 Filesize:  21.03 KB
HD8 Original Label
 Filesize:  23.05 KB
HD8 RevB Colour Filtered
 Filesize:  19.25 KB
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 11:46 am    Post subject: Reply with quote
Actually my above picture of the Colour filtered HD8 is Wrong..........
They DO exist but I do not have a picture of them.....
What I think THEY are is a very early set, newer lens use a "ML" "multi layer" coating and appear almost clear to the eye......
What they are is early "NON Multi layer" lens, which give off a coloured light when looked at..........
There is one well know guy here/avs - I think he works on optics, your guys might know his name, SORRY I forget.............
Im looking up some of my notes.........
EDIT - cant find my notes.........
Anyway, I dont wish to take credit that is due to others, I think it might be "Mark -A W" does that sound right ???
Anyway there was a very informative thread about NON ML lens features....Maybe someone can point us to that......
On with me picture...........
PS - YES I KNOW I got more lens than Pete !!! I have a lens fetish, Im begining to see the signs........MOST of these lens I have here! I guess Curt has some more.............
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 11:53 am    Post subject: Reply with quote
Wanted to say a BIG thank you to Tom, he has collected loads of Lens info, posted on the Evil Twin, Many thanks for the time to do this, It is a very useful set of data (NOW HERE) and a real great help to all of us.
Also thanks to Kal and Curt for the web site that will keep CRT alive, any onfo that we can all give to add to this site I think is a great thing.
And we might help Kal get another Barco Laughing
PS - loads more pictures still to come...........
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 11:56 am    Post subject: Reply with quote
HD9 anyone ???
I think these are found on Early Barco 1200's - im not 100% sure about these.....
Maybe the early 9 inch manual conv Barcos ?
Curt???
NOTE : These EARLY 9 inch LC Lens have a squared off front end, Later HD10 style have an angled front edge.
HD9 Label
 Filesize:  18.91 KB
 Viewed:  61580 Time(s)
HD9
 Filesize:  52.71 KB
HD9
 Filesize:  63.69 KB
 Viewed:  61581 Time(s)
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 12:00 pm    Post subject: Reply with quote
HD10 GT26
(9 inch LC section - Yeah, I know you all knew that!)
HD10 GT26
 Filesize:  18.24 KB
 Viewed:  61577 Time(s)
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 12:04 pm    Post subject: Reply with quote
HD 144's ALL colour filterd in this set.
The "Complete set" are from an NEC projector - they put a WHITE ring round them, not sure why, Maybe like barco to make them slightly different to other brands - Maybe even USPL insist on a change ???
(NOTE TO SELF - need to add NON colour filtered of HD 144/145 and show how really sad you are to have them all!!!)
PS - DONT KNOW WHY these pictures dont show like the others.......
HD 144 Colour Filtered Complete Set
 Filesize:  75.46 KB
 Viewed:  61124 Time(s)
HD 144 RED Colour Filtered Set
 Filesize:  78.37 KB
 Viewed:  39575 Time(s)
HD 144 Gren Colour Filtered Set
 Filesize:  97.13 KB
 Viewed:  39519 Time(s)
HD 144 BLUE Colour filtered set
 Filesize:  89.14 KB
 Viewed:  39515 Time(s)
Mad Mr H
PostLink    Posted: Tue Nov 14, 2006 12:08 pm    Post subject: Reply with quote
HD 134
HELP! Where are these from......Sony G70 ??? Maybe.........
HD 134
 Filesize:  81.82 KB
 Viewed:  61567 Time(s)
HD 134
 Filesize:  97.31 KB
 Viewed:  61568 Time(s)
HD 134
 Filesize:  89.17 KB
 Viewed:  61570 Time(s)
Page 1 of 12
