CRT Design to Prevent Flicker?
HogPilot
PostLink    Posted: Sun Aug 01, 2010 11:22 pm    Post subject: CRT Design to Prevent Flicker? Reply with quote
Guys,
Someone posted this about CRTs over in the "other" forum. He has an alarming propensity to make crap up when it suits him, and since I know nothing about CRTs, I figure someone here would have to know if this were true, quasi-true, or total B.S.:
When watching video in even semi-darkened room, some means of suppressing the flicker must be used. For decades the main technique used to make CRT TV displays viewable without flicker was to power the CRT B+ plate voltage from a high voltage power supply which imposed a 120Hz "ripple" that basicly caused a 120Hz brightness change in sync with the 60Hz room lighting.
As I understand it, flicker isn't even an issue unless you have some sort of pulse-driven display (like CRT or plasma) in a room with lighting that's also pulse-driven (like fluorescent lights), and the lights are operating on a different refresh frequency than the display. But either way, is the above description anywhere near correct? If anything is incorrect, would you mind correcting me or him and helping to get the facts straight?
PostLink    Posted: Mon Aug 02, 2010 5:12 am    Post subject: Reply with quote
Are you asking about vertical refresh rates ?
http://en.wikipedia.org/wiki/Refresh_rate
Moderator
PostLink    Posted: Mon Aug 02, 2010 4:29 pm    Post subject: Reply with quote
I don't remember hearing anything about this for North American CRT RPTV's but Europe had some that were 100Hz. As far as I can tell that was only when you ran a 576i signal into them
Phil Smith
PostLink    Posted: Mon Aug 02, 2010 4:36 pm    Post subject: Reply with quote
Is this off topic? Wink
Moderator
PostLink    Posted: Mon Aug 02, 2010 4:39 pm    Post subject: Reply with quote
No actually it should be in the Direct view section Laughing
HogPilot
PostLink    Posted: Tue Aug 03, 2010 2:08 am    Post subject: Reply with quote
Ha, dammit, I should probably re-post this over there. Thanks for the point in the right direction Smile
Moderator
PostLink    Posted: Tue Aug 03, 2010 2:17 am    Post subject: Reply with quote
Why didn't you just ask me to move it?
EDIT: Done!
HogPilot
PostLink    Posted: Tue Aug 03, 2010 2:37 am    Post subject: Reply with quote
EDIT: Done!
Thanks Embarassed
