Sparky015
Joined: 12 May 2009 Posts: 1160 Location: Cleveland / Akron, OH
Link Posted: Fri Mar 19, 2010 3:08 pm Post subject: |
Hey guys, just curious. Because of the change in material, and the new bellow's ability to keep outside moisture out, I would think that the expansion inside the chamber is less than a stock bellow. If that is the case, would you recemmend putting in more glycol after the change, or still the same amount?
_________________ ~Paul
Joined: 12 Jan 2007 Posts: 12842 Location: West Seneca NY
Link Posted: Fri Mar 19, 2010 4:35 pm Post subject: |
I have had no problems with the proper amount of Glycol. The Expansion some people see is not because of the glycol expanding with heat, it is because of the absorption of moisture. The Older bellows , like the sweating one pictured on the sales page, expand like that when cold too.
Sparky015
Link Posted: Fri Mar 19, 2010 4:42 pm Post subject: |
Ok, thanks. I would imagine this would keep the glycol from getting contaminated over time as well, as it would keep the bacteria and all of that out as well. Thanks!
Link Posted: Sat May 22, 2010 1:09 am Post subject: |
I just ordered a set for myself. Athan reports that his second order of them is in stock.
The list of things I'll be doing to my Marquee during this refurbishment period is considerable. Redoing the bellows (the tubes are still VERY minty!) due to leakage and some glycol contamination is a top priority. And there's so much more to do.
CJ
Link Posted: Thu May 27, 2010 12:44 am Post subject: |
I just got my set. I'm very familiar with the originals and have an unused example of them lying around for comparison.
The new ones actually seem to be even more precisely made than the originals. Good job!
CJ
Link Posted: Thu May 27, 2010 3:25 am Post subject: |
| cmjohnson wrote: | I just got my set. I'm very familiar with the originals and have an unused example of them lying around for comparison.
CJ |
Thanks Chris but Dale is the one who reversed engineered it and the machinist who made the mould deserve the credit.
I asked Dale if there was anything he could improve on the design so we would not need to use RTV so the bellow might be able to be removed with out cutting it up. He said he'll test the compression of the existing ridges , he said he thinks he could improve on it and he did. No RTV is needed on either the face plate side or the C-element side. And the material has a vapor
transmission 7 times better than the original.
Link Posted: Thu May 27, 2010 3:52 am Post subject: |
I do have a question for you.
These obviously have a mold release chemical on them. What is the recommended cleaning agent for completely cleaning them prior to installation?
When I put mine on, I truly want to try to approach "clean room" conditions as much as I can. Which includes making the new bellow
as squeaky clean and free of any dust, dirt, or contaminants as possible, just like the LC chamber and CRT face and C element.
CJ
dturco
Joined: 06 Feb 2009 Posts: 3747 Location: Eastern Shore Maryland
Link Posted: Thu May 27, 2010 11:56 am Post subject: |
When I installed mine last year I rinsed them in the sink, then I used bottled spring water for a final rinse. I also did not use any silicone on the bellow or C-element,and have had zero problems.
http://www.hulu.com/firefly
mycatisretarded
Link Posted: Tue Dec 28, 2010 5:14 pm Post subject: |
I'm about to order a set of three, is price and availabity still as as advertised? ("Special Christmas price?", he asked hopefully)
AnalogRocks Moderator
Joined: 08 Mar 2006 Posts: 20966 Location: Toronto, Ontario, Canada
Link Posted: Tue Jan 04, 2011 7:32 am Post subject: |
Go with the non carbonated to avoid bubbles
