My dumb HD question of the day
PostLink    Posted: Sun Jan 24, 2010 4:32 pm    Post subject: My dumb HD question of the day Reply with quote
So... I was spending some quality reading time in the bathroom this morning, with a copy of the 'Absolute Sound' from 2007, where they reviewed a number of flat screens. THis is the era where many flat screens couldn't accept a full 108p HDMI signal, but the panel itself was 1920 X 1080 and upconversion was done internally.
Reading the specs, I noticed something interesting. All HDMI input specs were 37Mhz for the video bandwidth. Why? Why then are us analog guys trying to find 150Mhz specs, and Mike is modding boards beyond that?
I'm missing something.. what is it?
PostLink    Posted: Sun Jan 24, 2010 5:09 pm    Post subject: Reply with quote
Uh, compression in the codec?
CJ
PostLink    Posted: Sun Jan 24, 2010 5:19 pm    Post subject: Reply with quote
CJ
Compression codec? I thought HDMI was transporting uncompressed. Damn boat keeps missing me. Mr. Green
PostLink    Posted: Sun Jan 24, 2010 5:21 pm    Post subject: Reply with quote
How about the simple explanation. The HDMI speed is a digital signal and the latter is an analog signal.
tse
PostLink    Posted: Sun Jan 24, 2010 5:22 pm    Post subject: Reply with quote
If the video format is 1080p @ 24Hz the bandwidth will be alot lower than 1080p @ 60Hz. The digital stuff will work with the low refresh inputs.
Scott
Thomas Jefferson
PostLink    Posted: Sun Jan 24, 2010 5:31 pm    Post subject: Reply with quote
The specs don't say in the review. Would I be wrong to assume that at say 720p/60, the video bandwidth of a digital set needs to be the same as an RGB analog input?
PostLink    Posted: Sun Jan 24, 2010 5:39 pm    Post subject: Reply with quote
One more time. The speed of HDMI is in Gbit/s............
720p/1080i 8-bit is 742.5 Mbit/s per channel, 1080p 8-bit is 1.65 Gbit/s per channel, 1080p 12-bit DC is 2.23 Gbit/s per channel and so on.
PostLink    Posted: Mon Jan 25, 2010 11:21 am    Post subject: Reply with quote
You know, the 'one more time' is what it took. Very Happy
PostLink    Posted: Mon Jan 25, 2010 3:53 pm    Post subject: Reply with quote
Mac, call me stupid, but I still don't understand.
I looked at the review again, and it says: H bandwidth 37 Mhz.
Oh, and this is on component as well as HDMI.
PostLink    Posted: Mon Jan 25, 2010 3:56 pm    Post subject: Reply with quote
You got a make and model on the one being discussed? I want to read it before I comment. Something else doesn't make sense in your first post.
Let me get it in a bit.
PostLink    Posted: Mon Jan 25, 2010 10:54 pm    Post subject: Reply with quote
Here's another possibility: See all those pins on the HDMI connector? Or DVI connector? There are multiple data streams running on
the cable. Each individual one of them may be no more than 37 MHz but the aggregate bandwidth may be much higher.
CJ
