Wisonart screen
dturco
PostLink    Posted: Mon Oct 12, 2009 4:52 pm    Post subject: Wisonart screen Reply with quote
I am going to be installing my Wilsonart DW 354-60 screen.
Here are some pics. http://s955.photobucket.com/albums/ae34/dturco/
Wilsonart material will be here Tomorrow 10-13-09.
I will have to reinitialize GOZER for this anyway and because of hight restriction I cant lower GOZER I have 8ft ceilings it's already in headsmackin territory for some of my guest, but not me or the wife. So I was thinking of tilting the screen to lessen the keystone. I think I can get about 10 degrees of tilt without to much work. The screen will be about 5" off of the viewing wall, so I'm thinking of pulling the bottom in with a wire or such. This will tilt the screen down towards the floor and give a better perceived brightness also?
There is some adjustment to be had from GOZER just not to much I would think. Is this the right approach?
http://www.hulu.com/firefly
CRT_Ben
PostLink    Posted: Mon Oct 12, 2009 5:06 pm    Post subject: Re: Wisonart screen Reply with quote
I will have to reinitialize GOZER for this anyway and because of hight restriction I cant lower GOZER I have 8ft ceilings it's already in headsmackin territory for some of my guest, but not me or the wife. So I was thinking of tilting the screen to lessen the keystone. I think I can get about 10 degrees of tilt without to much work. The screen will be about 5" of of the viewing wall, so I'm thinking of pulling the bottom in with a wire or such. This will tilt the screen down towards the floor and give a better perceived brightness also?
If I understand what you are saying correctly - pulling the bottom of the screen closer to the screen wall (away from the viewers), you'll make your keystone worse. To eliminate keystone the screen needs to be perpendicular to the angle of the tubes, so you'd need to pull the bottom towards the viewers and away from the screen wall (or opposite if you moved the top of the screen). Either way, I wouldn't do it, the projectors are built with some keystone adjustment in mind.
PostLink    Posted: Mon Oct 12, 2009 5:07 pm    Post subject: Reply with quote
Careful with that. The optics are designed to delivery sharp focus in a vertical plane. If you tilt the screen, you might be able to compensate with the Scheimpflug adjustments, but I'm not sure how much screen-tilt they can counteract.
Moderator
PostLink    Posted: Mon Oct 12, 2009 5:43 pm    Post subject: Re: Wisonart screen Reply with quote
You can run a 0 deg's to the lenses BUT. Keep in mind the projection angle is there for a reason. You really don't want the screen reflecting back to the projector. You want it reflecting back to the the audience. When you get the willsonart you'll see what I mean.
The Wilsonart has a reflectivity to it and you'll find by tilting the screen up and down you'll find the sweet spot for your projection angle. Just aim the reflection at your favorite chair and you'll be fine.
dturco
PostLink    Posted: Mon Oct 12, 2009 5:51 pm    Post subject: Reply with quote
So, I just wing it as usual. Smile Confused
I think the P/J has 15 degrees tilt already there? Tilting the screen down towards the floor would be increasing this angle, so not good for keystone but better for reflecting the light towards the viewer? Tilting up would send the light to the ceiling and make the ceiling brighter not the viewing area?
So what is the answer? Is there one?
Moderator
PostLink    Posted: Mon Oct 12, 2009 6:08 pm    Post subject: Reply with quote
Yes. STOP OVER THINKING THIS! Laughing
In the immortal words of the sneaker commercial.
Just do it.
dturco
PostLink    Posted: Mon Oct 12, 2009 6:14 pm    Post subject: Reply with quote
Just do it.
Come on, S P E L L I T O U T F O R M E Laughing Embarassed
TV/Projector: JVC RS45
PostLink    Posted: Mon Oct 12, 2009 7:28 pm    Post subject: Re: Wisonart screen Reply with quote
I'll just add this... If you sit right under your ceiling-mounted projector, with the screen perfectly plumb, any resulting hot spot should be about in the middle of the screen; maybe the upper-middle if you have a low ceiling and sit upright.
Unless you were to tilt the screen a LOT one way or the other, the screen will already be aiming the reflection at you. The exception would be if if you sat über-close (<1x screen width) or way far back (>2x screen width).
I could tilt mine down to move the hot spot more toward the center, but why? With the small screen sizes and short throws that most us run, you'd almost certainly run out of Scheimpflug and top-bottom focus would suffer - and to what end?
In short, you don't need to do damn thing in the way of tilting. Just hang it up and watch some movies!
dturco
PostLink    Posted: Tue Oct 13, 2009 6:59 pm    Post subject: Reply with quote
sh*t.
I called to see if the Wilsonart was in. The very nice lady says to me, oh when they delivered it, it was snapped in 2, so we refused the order and a new piece will be here on Thursday. You didn't want that piece anyway.
She of course is right but, sh*t, Wait some more. Rolling Eyes
And of course better it snapped on them, then me. Twisted Evil
akajester
PostLink    Posted: Tue Oct 13, 2009 8:37 pm    Post subject: Reply with quote
take some pics when it's all done so we can see how the install went.
dturco
PostLink    Posted: Tue Oct 13, 2009 8:42 pm    Post subject: Reply with quote
I will add them to the Photobucket site with the frame pics. I intend to screw the top and bottom every 6" and the sides at 12" and use silicone on the frame boards also.
Jim Shonk
PostLink    Posted: Fri Oct 16, 2009 1:50 am    Post subject: Reply with quote
Just thought I would chime in. I am more of a lurker here and not much of a poster, however I built a Wilsonart 92 inch 16:9
screen this spring just to see if the buzz about it was legit, This screen out preforms my dalite 1.5 gain hands down, I love this surface, you can clean it with windex and it looks so silky and smooth. I have used a very low hour G70 as well as my hoped up marquee 9000lc, I must say I will never go back, I am shocked that somebody hasn't marketed this surface for projection use yet, I have not noticed a single hot spot in any movie I have watched, I have seen a bit on video sports and stuff but very minimal, And for the overall performance gain over any other surface I have tried its a small price to pay.
I glued my laminate to a 1/4 inch thick 4x8 particle board and used 2 aluminum seal strips one mounted to the wall up right the other mounted to the back of the particle board facing down, forming a 4 foot hook so to speak to mount it. I was able to pick it up and hang it myself if you were wondering about the weight
I hope you enjoy yours as much as I do mine, it's just perfect in my book.
I like to focus Nakid
dturco
PostLink    Posted: Fri Oct 16, 2009 3:56 am    Post subject: Reply with quote
Quick answer to the Wilsonart, it is so much better than what I was using. Jim has it right, you really need a substrate to get it perfectly flat without hassel. My frame did not allow for perfection but damn good. A Slight bit wavy at the edges, not the top or bottom though. Still much better than the pull down waves for sure.
Well worth the trouble. Thumbs Up
I took pics and will add them tomorrow. Smile
Edit : Crap, overnight I had a blow out on the side where one of the waves were. I put an extra screw there to "flatten it out" and it stressed the Wilsonart, it cracked, well no, it chipped a 1.5 inch chunk out.
I will glue it back in and use white out to conceal it.
So If you are going to use the Wilsonart use some substrate like luan or insulating boards, whatever but definitely use something and glue. It is made to be glued down so....
But that is my fault not the Wilsonart's. It performs great for picture quality on the first view, I just turned on the P/J and let it throw the image on the screen without changing the set-up, so the picture did not fill the screen, but looked great in the "box" it was in. Of course my settings were off so I did a quick adjustment to them and the colors are just so much sharper and cleaner.
PostLink    Posted: Fri Oct 16, 2009 2:59 pm    Post subject: Reply with quote
Gary Brown glued his to some 1/2" construction foam of some kind. Made it completely rigid, but it was very light and easy to work with.
dturco
PostLink    Posted: Fri Oct 16, 2009 3:59 pm    Post subject: Reply with quote
I should have used a substrate. I know better but I rushed it to get it done and that caused the problem. My leftovers frame idea doesn't help much, the door jambs I used for the sides seemed like a good idea, but in fact caused a problem setting the Wilsonart down in between them. If I had used just flat material I don't think this would have happened.
Still the Wilsonart looks great. I think it's to early to decide if it's perfect but it sure is an improvement.
Although this does prove to me that for anyone else doing this a substrate is necessary.
My method was to lay the frame flat on the floor then put the DW in place dry. I then applied some adhesive caulk to the frame boards, then layed the DW down again. Then I drilled holes every 8" top and bottom, 12" on the sides. The door jamb weather stripping was a bitch to push back in and caused to much pressure and I used an extra screw to "help" things, which again caused a problem.
Hopefully my mistakes will help someone else. It really isn't hard to do, but as with anything the first time you can make little mistakes that cause an unknown problem to arise.
So to sum it up, my poor frame design and the lack of a substrate, caused a problem not the Wilsonart.
Sparky015
PostLink    Posted: Fri Oct 16, 2009 4:33 pm    Post subject: Reply with quote
I think this thread convinced me this is the way to go. I was contemplating a $1K Da-lite Hi-Power, but spending more on a dumb screen than my projector was making my stomach queezy. Embarassed
I like the idea of rigid foam for the backing. Cheap and light. Where have you guys found the best spot for ordering the WilsonArt material for the money?
dturco
PostLink    Posted: Fri Oct 16, 2009 4:59 pm    Post subject: Reply with quote
http://www.wilsonartcontract.com/directory/finddist.aspx
It's been found that the shipping costs will eat any savings so buy it from someone near you, it shioludn't be more than $150 for a 5x12 DW-354-60 standard grade not vertical grade.
shioludn't ? HTF did I type that?
akajester
PostLink    Posted: Fri Oct 16, 2009 5:01 pm    Post subject: Reply with quote
I made a 7ft wide 16x9 screen out of melamine. I also ordered a sample of wilsonart and to be honest couldn't tell the difference, although it was a small sample.
Pros
1. melamine was $35 for a 4x8 sheet
2. already on 3/4" substrate, no glueing necessary.
3. you can buy it at Home Depot
Cons
1. it's heavy!
2. limited in size, 4x8 sheet.
Anyways, I would recommend checking out the melamine first. If you don't like it you can return it to the store too, as it's not special order! Smile I literally brought it home, cut it to 16x9 with a circular saw, mounted it with some L brackets to the wall framing and cleaned it with some windex.
Sorry, not trying to thread steal here.
PostLink    Posted: Fri Oct 16, 2009 5:34 pm    Post subject: Reply with quote
The other Con for melamine is that it isn't standard. Clarence bought some melamine from HD a few years ago and thought it was great. I went to my local HD and looked at the exact same SKU, and you could almost see your reflection in it. Apparently they use different suppliers for melamine. Some of 'em look great, others would blind you with hotspotting.
Wilsonart should be standard. It's been measured and been shown to be a very good screen surface, and the Designer White you get should be nearly identical to the DW that they tested -- and the DW that many people have tried and loved.
Sparky015
PostLink    Posted: Sun Oct 18, 2009 12:26 am    Post subject: Reply with quote
Thanks for the info. I found it in stock at a local floor and tile store. $136 for a 5x12 sheet. On to the frame!
Jim, Your particle board backing idea is interesting. I was thinking of doing something similar wth the pink rigid foam, but I think the particle board is more the way to go. My only concern is keeping the particle board from warping, but I suppose strategically placing the mounting forks would keep that from happening.
Did you use felt tape to create your boarder then? Did you also picture frame the sides to enclose it, or just leave it open?
~Paul
