A new Edge Blending unit from TV-One will be coming out soon, Donald K linked this over from the A sites TV-One how too thread. I am awaiting Release And Pricing info for these units. Once I find out I'll post the info here:
Edge Blending made easy with new dedicated unit from TV One
MARGATE, Kent UK, 24th August 2009 – TV One announces the release of the new C2-2450A Edge Blender. This powerful and dedicated edge-blending unit is based on TV One’s exclusive CORIO®2 Technology and has been developed specifically to facilitate quick and easy set up of otherwise complex edge-blending applications.
A single DVI or RGB source at virtually any resolution and refresh rate is simultaneously fed into two or more separate C2-2450A units and using their integral processing engines, this video is prepared and output to multiple projectors and blended seamlessly together to create larger, brighter displays.
Set up and operation is made simple with dedicated front panel push buttons for various functions including turning the edge-blend guidelines on and off and also for switching to a full black or white output. The black output assists with the black level adjustment, whilst the white output aids in gamma correction to compensate for many of the problems faced when blending projectors. All functions can be controlled via the front panel, infrared, RS-232 or IP. An easy-to-use edge-blending software tool is also freely available allowing for even simpler operation of the C2-2450A.
Ten user defined presets are available to customise settings for various applications and due to the unit’s non-volatile memory these settings are retained even when power is switched off. Pixel accurate scaling is available to support any edge-blend application with images from multiple units aligned vertically, horizontally or both to create unusual displays. The unit is housed in a desktop case and an optional rackmount kit holds one or two units.
This brand new product will be on display throughout the entirety of the IBC 2009 Exhibition held September 11-15 at the Amsterdam RAI on the TV One Stand 7.F10. For more information visit www.tvone.eu or contact the Sales and Technical Department on +44 (0) 1843 873311, sales.europe@tvone.com. "
EDIT: Added press release text ~AR _________________ Don't blame your underwear for your crooked ass~ unknown Greek philosopher
Joined: 12 Jan 2007 Posts: 16170 Location: West Seneca NY
Link Posted: Mon Aug 24, 2009 8:59 pm Post subject:
Are you in their beta tester program?
No, but they give me dealer pricing , and because of their relationship with some on line sellers i am not allowed to publish what i can do price wise for the small amount I might sell.
