electrohome needs some help
lackenator
PostLink    Posted: Sun Apr 19, 2009 4:42 am    Post subject: electrohome needs some help Reply with quote
Electrohome ECP 3100. does not power up at all. the cpu card lights on the rear of the machine do not come on when plugged in like they should. i have tried replacing the low voltage power supply and the cpu card. has anyone else had this problem? and if so, any suggestions?
"And......it's dead again."
Moderator
PostLink    Posted: Sun Apr 19, 2009 4:54 am    Post subject: Reply with quote
Off the top of my head I'd check the conectors to make sure they aren't off by one pin. That's pretty common. ALso try reseating all the boards.
Nice sig line. "And.......it's dead again."
That would have worked well for my Ampro 4000 for the first 18 months. Laughing
PostLink    Posted: Sun Apr 19, 2009 6:32 pm    Post subject: Reply with quote
Hello
You may have issues with the power entry module, it is the section that the power cord plugs into.
lackenator
PostLink    Posted: Sun Apr 19, 2009 9:10 pm    Post subject: Reply with quote
i pulled the power entry module, noticed the fuse on it. i hoped it was that, but the fuse was still good. what else could be wrong with it besides a blown fuse?
PostLink    Posted: Sun Apr 19, 2009 9:27 pm    Post subject: Reply with quote
What Tim said. On the PC board somewhat hidden is a 1 amp (?) fuse that could be blown. There's also a standby transformer on that entry module that provides the standby supply for the IR. I've had that transformer go open once. I have spares for cheap if you want one, both of the input module and transformer.
lackenator
PostLink    Posted: Sun Apr 19, 2009 9:37 pm    Post subject: Reply with quote
the fuse was still good, but i havent checked the transformer yet, but i do have a replacement. hopefully that works. i have a whole projector's worth of extra parts. so im set for a while. Im going to try replacing the transformer first. ill get back to you guys after this little energy adventure!
lackenator
PostLink    Posted: Mon Apr 20, 2009 8:14 pm    Post subject: Reply with quote
I have replaced the power entry module but now the high voltage power supply will not power up
F16wes
PostLink    Posted: Mon Apr 20, 2009 9:49 pm    Post subject: Reply with quote
John I hate your projector.
lackenator
PostLink    Posted: Mon Apr 20, 2009 9:54 pm    Post subject: Reply with quote
well it hates you too. cuz you broke it.
lackenator
PostLink    Posted: Tue Apr 21, 2009 12:05 am    Post subject: Reply with quote
ok. for real though. besides a blown fuse (or having a friend shatter it) what could cause the HVPS to not power up?
lackenator
PostLink    Posted: Sun May 03, 2009 4:45 am    Post subject: Reply with quote
Hey Curt, i think i may need to buy a new power entry module and transformer from you. how much would they cost with shipping to florida?
