Lost Convergence on Marquee 8500
CRTVoyager
PostLink    Posted: Wed Sep 03, 2008 9:58 pm    Post subject: Lost Convergence on Marquee 8500 Reply with quote
Hi guys,
I have the following little problem. Everytime I start my 8500er out of stand by and want to watch a movie via my Notebook ( DVI out ) to HD Fury in and VGA to RGBHV, 720p 60HZ I need to reajust the convergence. If done this a couple of times and saved it at the end, but I have to do the same work everytime again. What can there be done?
GEBrown
PostLink    Posted: Wed Sep 03, 2008 10:07 pm    Post subject: Reply with quote
Well, the first question that comes to mind is:
If you wait a few minutes and let the PJ warm up, does the convergence fall back into line?
PostLink    Posted: Wed Sep 03, 2008 10:15 pm    Post subject: Reply with quote
Are you locking the source after? After you set up your PJ convergence make sure you lock the input so it does not change this happens also if you have ASR or ASI on i keep them off and save each input and recall separatly. After you converge , press utilities 1> then 3 to lock or unlock the source setting.
or it could be the battery is running low on the CLM.
