Kim, What About an Analog Blend Box or Two?
Person99
PostLink    Posted: Fri Mar 07, 2008 10:12 pm    Post subject: Kim, What About an Analog Blend Box or Two? Reply with quote
Kim,
OK, this came up awhile ago, but I can't remember where it went. Why can't we do blending in the analog domain? It seems fairly straight forward if we are willing to use PJ controls and waste bandwidth to achieve what we want. Let me see if I can communicate this clearly then you can tell me if it makes sense. Smile
Basically, I'm looking for a box that looks like a simple 1x2 distribution amp; however, we could do the blend boxes as two boxes that sit between a distribution amp and the PJs. To make it simpler, lets say we do that. So, I send a signal to a 1x2 distribution amp. I take those two signals and feed them to a "left" box and a "right" box.
The boxes basically have a preset contrast modulation curve in them. So the left box tapers the contrast in a curve on the right side of the image and the right box tapers the left side. Now, they are both getting the whole picture, but they really only need about 3/4 of the picture. So, we let the modulation start point be adjustable. So, you can adjust the left and right for a perfect blend point.
So, Each PJ is getting the same image--using all the bandwidth for 1920x1080 or 1920x817 (however they user has set it up). This is the downside, since if fact, our little right or left box has modulated the contrast down to nothing, or basically a black pixel for about 1/4 of the picture. So, it would waste bandwidth, but we can use the projector's controls (blanking, H Pos, H Phase) to "get rid" of the part of the picture we are not using.
Am I crazy thinking this is not too hard and not too expensive, or am I smoking crack? When can you have it to me to test? Very Happy
beun
PostLink    Posted: Fri Mar 07, 2008 10:48 pm    Post subject: Reply with quote
Dave,
In the end it went nowhere mostly because of feature creep that could only be performed in the digital domain. Your idea is sound and seems technically possible. I am pretty sure that when I start to design numerous technical problems will rear their ugly heads but it sure could be worth a try.
Kim
Clarence
PostLink    Posted: Fri Mar 07, 2008 11:09 pm    Post subject: Re: Kim, What About an Analog Blend Box or Two? Reply with quote
http://www.curtpalme.com/forum/viewtopic.php?p=13489#13489
Person99
PostLink    Posted: Fri Mar 07, 2008 11:27 pm    Post subject: Re: Kim, What About an Analog Blend Box or Two? Reply with quote
The search master! Thanks. It did got to what Kim said, features which could only be done in the digital domain.
Person99
PostLink    Posted: Fri Mar 07, 2008 11:30 pm    Post subject: Reply with quote
beun wrote:
Dave,
Kim
So, what do I have to do to get you thinking about it? Smile
If you had to ballpark it, what would an all in one box (distribution amp with left and right) cost and what would just a right box and a left box cost? Frankly, I think cost is going to be the driver of whether it is worth doing or not (but I'll take a 1 off--Smile).
If you would be willing to entertain it, I could see about borrowing Dan's D50 and I can get my hands on another D50 locally, so I could do some testing. And, I might be able to get two BG 808 machines. Smile
beun
PostLink    Posted: Sat Mar 08, 2008 3:00 pm    Post subject: Reply with quote
The cost would not be that high, probably not more than a RTC2200 for a 1 in 2 out.
Kim
aspec2
PostLink    Posted: Sat Mar 08, 2008 3:18 pm    Post subject: Re: Kim, What About an Analog Blend Box or Two? Reply with quote
Person99 wrote:
Kim,
Am I crazy thinking this is not too hard and not too expensive, or am I smoking crack? Very Happy
Dave.....can't you do both?
Walt
PostLink    Posted: Sat Mar 08, 2008 4:19 pm    Post subject: Re: Kim, What About an Analog Blend Box or Two? Reply with quote
aspec2 wrote:
Person99 wrote:
Kim,
Walt
Dave would end up selling the projector's to cover his habit Wink
Kim I really hope you give this a try !
CRT_Ben
PostLink    Posted: Sat Mar 08, 2008 6:31 pm    Post subject: Reply with quote
Ok, this is something that I just thought about that may or may not be a problem - even if we use the projector's blanking to cut off the non-active image area, in order to use the phosphor effectively, that blanked area would have to be nearly completely off the side of the tube face. Better of course than displaying active video on the side of the tube, but I'm not sure if there would be any long-term issues of having the beam scanning 20-30% of the picture width on the side of the tube?
I can say though, if you're talking the same price level as the RTC2200 (which I already have - you do fantastic work Kim!!), I would get one just to play with blending with my two Sony 12xx's.
beun
PostLink    Posted: Sat Mar 08, 2008 8:30 pm    Post subject: Reply with quote
The unused portion of the picture will be black so I don't think there is any danger of lighting up the side of the tube.
PostLink    Posted: Mon Mar 10, 2008 3:53 am    Post subject: Reply with quote
Kim,
If you could build this blend box and sell it for the price of the kimcoder I'm sure you would have lots of interest.
Moose
PostLink    Posted: Mon Mar 10, 2008 2:37 pm    Post subject: Reply with quote
I'd say there would be lots of interest even if it cost $500 or so.
Bruce 09
PostLink    Posted: Wed Mar 12, 2008 4:54 am    Post subject: Reply with quote
beun wrote:
Dave,
Kim
I would be willing to send you the blender I have for research or whatever you needed it for.
Bruce
PostLink    Posted: Mon Mar 24, 2008 6:14 pm    Post subject: Reply with quote
So, is this dead again?
beun
PostLink    Posted: Mon Mar 24, 2008 7:43 pm    Post subject: Reply with quote
It is not dead but delayed until I can the TC1500 designed finished.
PostLink    Posted: Fri Apr 04, 2008 4:37 am    Post subject: Reply with quote
Ahhh good way to do thing's. One at a time.
I really need to learn how to do that.
PostLink    Posted: Fri Apr 04, 2008 12:59 pm    Post subject: Reply with quote
are we talking a blend box like blendzilla????
I'd pay way more than 500.00 clams!
Person99
PostLink    Posted: Mon Apr 21, 2008 7:26 pm    Post subject: Reply with quote
No, we are talking about a blend box that does the blending in the analog domain (unlike a blendzilla). But, you could accomplish the same thing as you can with the blendzilla.
PostLink    Posted: Mon Apr 21, 2008 7:51 pm    Post subject: Reply with quote
Ummmmmm, whats the diff??? Neutral
tri_joel
PostLink    Posted: Wed Nov 19, 2008 2:42 pm    Post subject: Reply with quote
Any updates on this project?
www.vawinesnob.com
