| Author |
voodoo7869
Joined: 19 Oct 2007 Posts: 193 Location: Chicago, IL USA
| Posted: Fri Feb 01, 2008 10:27 pm Post subject: cpc magnet types. |
I am curious is this a 2/4 pole cpc? and if so i read somewhere that you could make it a six pole with magnets. I just don't remember where i saw it. thanks for the help
_________________ Marquee 8000 modded, Marquee 9500lc with LUGs, Frankenyokes, and Moome. My avatar is not just a black box. CRT Is KING!!!!
| Back to top |
fireanimal
| Posted: Sat Feb 02, 2008 1:22 am Post subject: |
??? Did you attach a pic
| Back to top |
Joust
Joined: 05 May 2006 Posts: 2429 Location: Almonte, Ontario, Canada
TV/Projector: Marquee 8501LC
| Posted: Sat Feb 02, 2008 1:32 am Post subject: |
I read that too.
you have to use some small rare earth magnets and arrange them on the ring material and let them sit overnight.
some CPC rings are un-magnetized. I have a couple sets that have 2 pole and 4 pole and a third set that are not magnetized at all. Its only that third set that you can do that with unless you have a way to "erase" the 2 or 4 pole version.
| Back to top |
voodoo7869
| Posted: Sat Feb 02, 2008 3:05 am Post subject: |
yes i did attach a pic I will reattach the pic again I am curious what rings are what
| Description: |
| Filesize: |
335.63 KB |
| Viewed: |
5444 Time(s) |
| Back to top |
voodoo7869
| Posted: Sat Feb 02, 2008 3:08 am Post subject: |
do the rings need to be in a specific order 2/4/6 2/6/4 etc?
| Back to top |
Joust
| Posted: Sat Feb 02, 2008 4:42 am Post subject: |
those are 2/-/4
there is no 6
| Back to top |
voodoo7869
| Posted: Sat Feb 02, 2008 5:32 am Post subject: |
would the six go in the middle does it matter where the 6 pole is in the config?
| Back to top |
Joust
| Posted: Sat Feb 02, 2008 6:02 am Post subject: |
i don't think it matters
| Back to top |
voodoo7869
| Posted: Sat Feb 02, 2008 6:22 am Post subject: |
cool I will try and magnetize the center rings to be six pole Just for giggles i will make the 6 pole rings closest to the front of the tube.
Do you know which is which 2 / 4 they have white on the tabs and yellow.
I cant remember white is 2 pole and yellow is 4 pole ???
Does that sound correct?
| Back to top |
Joust
| Posted: Sat Feb 02, 2008 6:25 am Post subject: |
the front ones are 2 and the rear ones are 4 IIRC.
| Back to top |
Joust
| Posted: Sat Feb 02, 2008 6:26 am Post subject: |
lay one flat , put a piece of paper over it and shake some iron filings on the paper. it should show the magnetic pattern.
old public school trick
| Back to top |
voodoo7869
| Posted: Sat Feb 02, 2008 6:48 am Post subject: |
sweet i will do thank you much i will let you know how it goes
Thanks again John
| Back to top |
tse
Joined: 03 May 2006 Posts: 1014 Location: Sweatbucket, Fl.
| Posted: Sat Feb 02, 2008 4:53 pm Post subject: |
Cool. I'd like to see the iron filings. Take a picture for us.
Scott
_________________ "Were we directed from Washington when to sow and when to reap, we would soon want bread."
Thomas Jefferson
| Back to top |
voodoo7869
| Posted: Sat Feb 02, 2008 5:49 pm Post subject: |
sure no problem
Do you think it would be wise to redo the fields for all the rings?
| Back to top |
Heywood Jablome
| Posted: Sun Sep 21, 2008 4:49 pm Post subject: |
Threadus resurrectus!
Any luck manually magnetizing the dead ring? I have a set I can pull from a 1208/2 that look just like that pictured, AND I have access to LOTS of ridiculously powerful rare earth magnets. (Not to mention several 800+ Joule magnetizing machines )
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
| Back to top |
| Back to top |
Heywood Jablome
| Posted: Sun Sep 21, 2008 5:51 pm Post subject: |
| Nashou66 wrote: | Wait you have acces to a magnetizing machine?!!!! We might be able to remagnatize regualr barco focus magnets and the do a rewind to the marquee specs and crank out some franken yokes !!!!!
Athanasios |
I have access to several very specialized magnetizing machines...
My company makes automotive sensors that use magnets and hall-effect (among other) sensors: The magnets we use are typically Neodymium-Iron-Boron ceramic, about 5/16" square and 3/16" thick, and are charged ten at a time (mainly because the LIQUID-COOLED coil takes two minutes to cool off enough for another shot!) Magnetizing ceramics requires a specialized field, created by a specially designed coil, so there really is no such thing as a generic magnetizer.
The CPC magnets will typically be a plastic that is highly loaded with ground ceramic magnetizable powder (such as NiB) and are actually magnetized IN the plastic mold when they are shot... While the plastic is molten a field is applied that concentrates the magnetic filler in the spots where the poles are to reside.
This is why I'm interested to know if anybody has been successful magnetizing a dead ring.
We've got one damn spiffy plastic magnetized-in-place ring that we use, which is actually shaped rather like a CPC ring, with 15 pole pairs. It's used as a rotary encoder with a hall quadrature counter on a motor-driven product we make.
This is contained within the production "SmartBar" (TM AA&M) sway-bar disconnect that American Axle provides to Jeep.
http://www.aam.com/index.php?s=48 (We are AA&M's tier-two on many products.)
Note that the picture on AA&M's website is of the Proof of Concept piece, which actually uses another actuator I helped create, but which looks NOTHING like the production SmartBar actuator.
--Edit: This site shows the best pic of the production unit that I could find. http://www.wawii.com/powerwagon/LegendaryDodgeRamPowerWagonReturns.htm
The smartbar actuator is the cast aluminum bit partially hidden behind the winch drum.
| Back to top |
