    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
NEC PG Tube Replacement
 (Page 4)
Page: 1 2 3 4 5
Step 12: Slide the CRT socket off the back of the tube itself
Step 13:
Remove the long bolts that hold the bottom of the tube in place.
Step 14:
You can now choose to take the lens off the tube assembly. I personally find it easier to grip the lens assembly while sliding the tube itself out, but taking off the lens will lighten the tube assembly by about 10 lbs.
Step 15:
Start sliding the tube assembly out the front of the set. You’ll need to snake out the HV lead as the tube comes out, and wiggle the astig magnet, focus and main deflection yoke backwards off the neck of the tube as the tube slides forward.
Step 16:
Here’s a shot of the tube assembly once it’s out of the set. There is one Philips screw in each corner of the tube that holds it to the mounting frame. Note the metal strap running across the bell of the tube in the pix below. This is the ground strap, and it’s mandatory that it is in place. If your new tube lacks the grounding strap, pull it off the old tube and screw it in place on the replacement tube.
... Previous Page
Next Page ...
