    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
NEC PG Tube Replacement
 (Page 3)
Page: 1 2 3 4 5
Step 10: Remove the HV lead from the appropriate tube you’re removing from the HV splitter. This is important! The HV lead snakes along the bottom of the chassis to the HV splitter. There are two plastic clips usually that hold the HV lead to the bottom of the chassis. They are somewhat hard to get to until the tube is partly removed from the set. Reach in with your fingers to loosen these clips.
VERY important! DO NOT pull on the red HV lead and expect the rubber boot to pull away from the HV splitter. These gray boots put quite a bit of suction on the HV lead, and you’ll end up ripping the HV lead out of the socket. Instead, slip a small jeweler’s screwdriver under the rubber boot to release the suction, then carefully slide the HV lead and boot off the HV splitter. Make sure you use an insulated screwdriver, and as a measure of caution, touch the inside metal connector to the chassis to short out any remaining voltage that remains. (there won’t be any, but that’s good high voltage practice!)
Step 11:
Time to loosen the magnetics (yokes and astig magnet) from the neck of the tube. The main deflection yoke and focus yoke have small thumbscrews that you loosen, so that the yokes can slide off the back of the tube.
The astig magnet has a Philips screw that holds it in place. Loosen it as well.
... Previous Page
Next Page ...
