    Site Map
Home FAQs, Tips,
Manuals
Referral
List
Gallery
Links Contact
Us
MUX-HD: HDMI/DVI Repeater
CURRENTLY SOLD OUT AND WAITING FOR NEWS ON WHEN THE NEXT BATCH WILL SHIP.
MUX-HD HDMI/DVI Repeater
$285 USD
Sign up today to receive the latest MUX-HD news!
Free priority shipping to anywhere in the world included!
Payment methods include PayPal and all major credit cards
(PayPal account *not* needed to pay by credit card).
Our payment processor will automatically convert the
amount to your local currency.
Orders ship direct from the manufacturer in Taiwan.
Warranty: 1 year all parts and labour.
Experience up to 1080p FULL HD from Blu-ray, HD-DVD, and other DVI/HDMI sources on any digital plasma/LCD/DLP TV or digital projector with an older DVI or HDMI input!
The MUX-HD allows you to easily add DVI/HDMI digital devices to displays with a non-HDCP compliant DVI or HDMI input such as an older PC monitor, HDTV/Plasma TV or digital projector.
By using the MUX-HD you achieve the cleanest digital path as you stay 100% digital all the way. Two Toslink digital audio output are also provided to allow you to feed up to 7.1 channels of audio to your A/V receiver or preamps. The MUX-HD is the ideal product for connecting multi HDMI sources to your digital display!
Need to add an HDMI switcher or HDMI cables?  See our recommended HDMI switchers & cables.
Specifications:
  • INPUTS: 4 HDMI inputs
  • VIDEO OUTPUTS: 1 HDMI and 1 DVI-D output.
  • HDMI 1.1/1.2, HDCP 1.0/1.1, DVI 1.0 compliant.
  • AUDIO OUTPUTS: 2 Toslink (fibre optic) digital sound output from the HDMI inputs. This can output compressed 7.1 channels or uncompressed 2 channel PCM. Note that the HDMI/DVI outputs do not contain embedded audio.
  • The HDMI and DVI outputs are functional at the same time (the MUX-HD can be used as a splitter).
  • Supports *any* resolution from 640x480 up to 1600x1200, including all the popular resolutions such as 720p, 1080i, 1080p, etc. (Any resolution and refresh rate up to 165Mhz pixel clock is supported).
  • DTV mode support (480p, 576p, 720p, 1080i, 1080p) for 50 and 60Hz
  • PC mod support (VGA, SVGA, XGA, SXGA, UXGA) up to 165Mhz
    Supports 4:4:4 RGB / YCbCr (digital component) Input
  • Supports 4:2:2 YCbCr (digital component) input
  • Supports both 16-235 and 0-255 colour range and auto selects correct value
  • Able to drive cables up to 10 meters (approx 33 feet) in length
  • IR remote control for input selection
  • Manual selection of input port available too
  • Metal case providing a clean electrical environment for high definition content processing
  • Global power supply (100V-240V)
Installation takes 5 minutes!
Reviews/Testimonials
"Moome has been kind enough to send me a pre-production version of the MUX-HD Repeater. It works perfectly. I have had up to 4 inputs connected to it (a Sony BDP-S301 Blu-ray player, an HTPC, a beta version of the Lumagen Radiance HD video scalar, and a Sony SAT-HD300 ATSC/NTSC/DirecTV tuner). The BDP-S301 and Radiance scalar output HDMI. The HTPC and ATSC Tuner output DVI. For these later two inputs I am using HDMI to DVI cables. The DVI output of the MUX-HD Repeater is fed directly to the Analog Way DVX-8022 BlendZilla blender/scalar/switcher (which has one DVI input). The HDMI output of the MUX-HD Repeater is fed to a Convergent Design nanoConnect HDMI to HD-SDI converter. The output of this converter is fed directly to one of the two BlendZilla HD-SDI inputs. I have fed the MUX-HD Repeater 1080P/24 (from the Sony BDP-S301), 1080P/60 (from the Sony BDP-S301, Radiance HD, and the HTPC), and 720P/60 and 1080i/60 (from the ATSC Tuner), and the MUX-HD Repeater has handled all of these input resolutions/refresh rates perfectly. I have not seen any errors introduced by the DVI/DVI Repeater. Yesterday I watched a series of football games in both 720P/60 and 1080i/60, via the Sony SAT-HD300 ATSC/NTSC/DirecTV tuner. Not a single instance of vertical motion tearing in any broadcast, with the exception of one commercial. The 12 foot wide blended CRT projected image was sharper, with more vibrant colors than I have ever seen in any TV image. It was like watching a 12 foot wide direct view CRT tube. So the results to date are: 720P/60 and 1080i/60 do not result in vertical motion tearing, whereas 1080P/24 does." - William
"We had a chance earlier today to check this unit out. We did not get to try the switching, but did get to send both 1080I and 1080P through the first input on the unit, and we also tried 1080/24P. We looked at both DVI out and the HDMI out. We ran the DVI out directly into the Diventix 8022 DVI input. We also had the HDMI out going into an HDMI to HD-SDI converter. Both work exceptionally well. Without the unit we would not have been able to connect directly into the 8022 or the converter. We had a Blu-Ray player on the first input of the unit. I was surprised how well the DVI to DVI connection from the unit to the input of the 8022 performed. It was a excellent. The HDMI into the HD-SDI is even better... Another product very very well done! Two thumbs-up!" - Mike Parker of MPmods.com (Video display guru)
"The picture quality on Blu-Ray and HD [Cable] Channels is unbelievable. GREAT work building this device." - Wayne R.
Need more information? See the MUX-HD FAQ!
Visit the Moome Discussion/Support Forum
Questions should be directed to the PJI-HD company (Moome) at: moome@curtpalme.com
When purchasing you will be paying and dealing directly with the third party seller 'Moome'.
While this item is not sold or supported directly by CurtPalme.com, we are in the service business and our only goal is your complete satisfaction. We work with our vendors to ensure you are completely satisfied.
