    Site Map
Home FAQs, Tips,
Manuals
Referral
List
Gallery
Links Contact
Us
Tim Martin's BlendZilla CRT Projector Stack
If you're looking for an incredibly large and bright CRT projection system then the BlendZilla from Tim Martin of E-Tech Systems (a friendly competitor to Curt) is an option you may want to consider.
Here is Tim's description:
We now have the technology to project stunning highly detailed and very bright images from CRTs using a special switcher/scaler/processor called BlendZilla. Sources can be HDTV satellite, DVD, HTPC, XBox 360, and other high quality signals fed through this processor and pairs of CRT projectors onto screens nine feet and wider. E-Tech will bundle the BlendZilla processor with retubed or new 8500 or 9500LC Marquees for systems ranging from $33,000 to $90,000 (USD) and assist in providing skilled installation almost anywhere. The projectors will display a left 60% and a right 60% of 16:9 using seamless overlap at 1024p for unparalleled image punch and detail.
A recent visitor had this to say: "As far as light output is concerned, even with a unity gain screen at 107" wide, the picture had a vast dynamic range. The projectors brightness was set in the low 40's for all viewing as there was absolutely no need for more light output. Subjectively, I would not hesitate using a 120" wide screen with this setup. I looked into all 6 tubes and it was a refreshing feeling to see the entire height and width of the raster being used!"
This system is demoed in Phoenix by appointment only, contact Tim at E-Tech to set your demo appointment.
Phone 480-368-743.  Email: ehometech@earthlink.net.
Pictures
Our demo system is two Marquee 9500LCs:
From Discovery HD:
From the Fifth Element NTSC DVD:
