Volume discounts available!
Contact Us for details.
Blu-Wire T1/R1 HDMI Extension Kit
Standard US (120V/60Hz)
power supply & cord |
Universal
power supply
with
IEC connector
(no wall cord)
Sign up
today to receive the latest Blu-Wire T1/R1 HDMI Extension Kit news!
Payment methods include PayPal and all major credit
cards
(PayPal account *not* needed to pay by credit card).
Our payment processor
will automatically convert the
amount
to
your local currency.
Worldwide
shipping.
Ships within 2-7 days after ordering.
Guaranteed to work or your
money back. |
Enable long-distance HDMI - up to 200 feet from source to display! Unlike most HDMI extenders ours is easy to set up, reliable, uses only one cable,
and has FULLHD 1080p support! No tweaking or adjustments required - it just
works!
Having issues with picture dropouts, blank screens, or dancing dots in the image?
You need to use our HDMI
extender!
Even the best HDMI cables are only certified to approximately 45 feet when
used as Category 1 ("Standard" 1080i/720p at 74.5Mhz) or 25 feet as Category 2
("High Speed" 1600p at 340Mhz). The distances are reduced in electrically noisy
environments or when lower quality (less expensive) cables are used.
The Blu-Wire HDMI T1 Transmitter and R1 Receiver provide a quick and easy method
of extending HDMI v1.3 or v1.2 + HDCP over cost-effective UTP (unshielded
twisted pair) networking cable. NO adjustments for ease of installation and maintenance,
and full 1080p + HDCP performance over SINGLE UTP CatX cable.
The Blu-Wire T1/R1 HDMI Extension Kit is produced by Obonok Technologies, the
world’s leading technology for HDMI signal distribution over category cable.
Two U.S. patents are pending on their proprietary technology used in this kit.
Need to go farther than 200 feet or split/distribute an HDMI signal?
Contact us for details!
How is the
Blu-wire T1/R1 Extender Kit better than other HDMI extenders?
- Other solutions require two CatX cables. Our solution uses only one
cable which reduces costs and making installation easier. Two less connections
also means 50% less chance of connection-related failures.
- Other solutions are only rated for 1080i and 1600 x 1200 with
bandwidth in the neighbourhood of 2 Gbps or less. Our solution supports FullHD 1080p with 6.6 Gbps of bandwidth. Future-proof your setup by making
sure your
HDMI extender supports 1080p!
- Other solutions are sensitive to cell phones and other
electrical noise such as fluorescent lighting causing noise and/or
dropouts. Our solution uses technology that is NOT sensitive to either - you
do not need to use more expensive shielded cables required by most of
the other
solutions.
- Other solutions require adjustment and tweaking to
maintain a
picture. Our
solution has Auto Gain and Auto EQ which results in a good signal regardless of
distance with no adjustments needed.
Hook-up
Hooking up the T1/R1 HDMI extender is extremely simple. Using short HDMI
cables, plug the T1 transmitter into the source and the R1 receiver into the
display then connect the two using a UTP networking cable and plug in the power
supply. Done!
Connections
Features
- Extend HDMI v1.3 / 1.2 + HDCP +
Power over a single UTP (CatX)
- HDMI extension to 200’ / 61m @
1080i/720p; 150’ / 46m @ 1080p
- Auto Gain / Auto EQ for plug-and-play
setup and zero maintenance
- Not sensitive to electrical interference
from nearby lighting or mobile phones
- Uses unshielded Cat6 or selected Cat5e
cables (see recommended cables below)
Specifications
- Total Bandwidth: up to 6.6 Gbps
- Maximum Resolution: 1080p / 1920 x 1200
- Maximum Distance (from transmitter to first
receiver): 200 ft. / 61m @ 1080i, or 150 ft. / 46m @ 1080p
- HDMI Connectors (1): Type A 19-pin F
- Link Connectors (1): RJ-45 F
- Power Supply: 12V DC (T1 transmitter
only—included)
- Power Consumption: 6 Watts (max.)
- Operating Temperature: -15C to 50C
- Storage Temperature: -40C to 85C
- HDMI Specifications Supported: v1.1, 1.2 &
1.3
- HDCP Compliant
- Cable Compatibility: Solid, bonded
Cat5e/6/7 (Cat6 or Cat7 required for 1080p applications)
- Gain / EQ / Skew Compensation: Automatic;
adjustment-free
- Dimensions: 71mm L x 64mm W x 24mm H
- Patents Pending: U.S. 60956694 and 60968046
Datasheet: T1R1_SpecSheet.pdf (340Kb).
Recommended UTP (network) cables
- Belden Home Choice 2510 Cat6
- Shaxon UL725-8 Cat6
- Belden 7988R Cat5e
- Solid, bonded Cat6 highly recommended for
1080p applications
- Not recommended: Stranded cable, “soft”
network jump cables, Belden 7987R/P or other "skew-free" cables
Note: Extension distance may vary due to differences in source material,
resolution, and cable. For example, cheaper Staples brand Cat5e at 1080i/720p
resolution can be expected to extend HDMI v1.2 approximately 100 to 125 ft. For
better results, use solid Cat6 or one of the recommended cables.
Need more information? See the 'Blu-wire T1/R1 HDMI Extension Kit FAQ' in our forum!
Visit the InteractAV Discussion/Support Forum
Questions?
Email us at: InteractAV@curtpalme.com
When
purchasing you will be paying and
dealing directly with the third party
seller 'InteractAV'.
While this item is not sold or supported directly by CurtPalme.com, we are in the service business and our only goal is your complete satisfaction. We work with our vendors to ensure you are completely satisfied.
DISCLAIMER (Legal mumbo-jumbo because we have to): Any dealings with the third party seller/manufacturer listed here,
including the delivery of and the payment for goods and services, and any other
terms, conditions, warranties or representations associated with such dealings
or promotions, are solely between you and the third party seller/manufacturer.
Curtpalme.com shall not be responsible or liable for any part of any such dealings or promotions.
CURTPALME.COM IS NOT THE SELLER OR MANUFACTURER OF THESE PRODUCTS OR SERVICES.
THE SELLER/MANUFACTURER MAY HAVE PROVIDED A WARRANTY ON THE GOOD(S) PURCHASED.
CURTPALME.COM HAS NOT MADE, AND DOES NOT MAKE, ANY REPRESENTATION, WARRANTY,
PROMISE OR COVENANT, EXPRESS OF IMPLIED, AS TO THE CONDITION, QUALITY,
DURABILITY, CAPABILITY, FUNCTION, PERFORMANCE, OR SUITABILITY OF THE EQUIPMENT,
ITS MERCHANTABILITY OR ITS FITNESS FOR ANY PARTICULAR PURPOSE. BUYER AGREES THAT
CURTPALME.COM SHALL NOT BE LIABLE FOR EITHER SPECIFIC PERFORMANCE OR ANY
LIABILITY, LOSS, TAMPERING, ABUSE, DAMAGE, INCLUDING CONSEQUENTIAL AND
INCIDENTAL DAMAGES, ARISING OUT OF BUYER'S PURCHASE OF THE EQUIPMENT, ANY
DEFECTS IN THE EQUIPMENT, OR FAILURE OF SELLER/MANUFACTURER TO TIMELY DELIVER
THE EQUIPMENT.
