Curt Palme CRT Projectors
Sign up and receive the latest newsletters by email!     Join the CRT Forum discussions!
    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Barco Setup: Quick Reference Guide
The following procedure was originally written by CRTEAMAN (James) and has been expanded on by Kal (the webmaster). Questions or comments should be posted to the forum in this thread
What this is
A quick reference guide that lists the order of the steps you need to perform when setting up pretty much any recent Barco projector. This will work for older units as well, though some of the steps will simply not be possible as the feature may not exist (ex: dynamic astig). In fact, 95% of the ideas in this quick reference guide could be used for pretty much any projector since the steps are generic enough.
What this isn't
An in-depth step by step guide on how exactly to perform all of these steps in detail for beginners. Beginners should simply follow the setup guide in their manuals. You may then use this list as the initial checklist for searching for other 'how-to' information.
Who should use this?
Advanced users that want a quick list of the setup steps they should perform to get 100% out of their Barco projector.
Who should not use this?
Users new to setting up CRT projectors in general. This is not a step-by-step beginner guide. Users new to setting up CRT projectors should follow the step by step guides in their manuals and keep their hands out of the unit. The only times they should be putting their hands near the projector would be to perform lens focus, toe-in, and scheimpflug (flapping). All other changes should be done via remote.
Warning: Many of the these steps involve you putting your hands inside the projector near 30-40KV rails. Do not attempt this if you are not comfortable doing this or know what you're doing. Skips these steps if you're not comfortable.
Initial checks:
(0) Ensure the projector is installed correctly (correct distance from the screen, correct height, and square to the screen).
(1) Check the 17 volt rail with a meter. Adjust if needed (see service manual). Make sure that you use a video line frequency 15.6/15.7 or an internal pattern, also your H-width setting must be at 49 when you do this.
(1a) Check the 48V pot on the SMPS (see service manual).
(1b) Check the horizontal linearity pot on the horizontal deflection board (see service manual).
Optical:
(2) Set the R and B raster to use most the CRT width, toe-in to center on screen properly (see Guy's excellent instructions here).
(2a) Do optical center focus, do corner focus, do Scheimpflug (lens flapping). (You need to go back and forth with these - very iterative). Guy has some excellent info on this using 3x5" recipe cards where you're attempting to see the phosphor grain on the screen (see link in previous step).
Tube magnetics:
(3a) Make sure the horizontal deflection coils are hard up against the tube bowl and in an a near upright position.
(3b) Start with the magnetic focus yoke as close to the tube bell as possible. Set center electronic focus to 57 and move magnetic focus yoke back (very slightly) if needed to get sharpest focus in center of screen.
(3c) Set the magnetic focus yoke rotation correctly. Start with completely upright/inline with deflection yoke. This good enough for most.
(3d) Set 2/4 pole magnets correctly to get astig at the center of the screen perfect. To test your astigmatism, do the following: Pull up your genlock pattern select focus in the menu's and one colour at a time turn the focus all the way up and then all the way down, watch for the little lines at the centre and see if they twist violently in a diagonal direction, if they do then your astig is bad!
(3e) Using a grid pattern, rotate deflection yokes until horizontal centerlines coincide. Don't worry about vertical lines being off (convergence will handle this). It's more important to line things up along the horizontal left to right center line.
(3f) For all 3 tubes, do zone astig if your projector has it (this is the outside astig. Center astig's already done with the 2/4 pole magnets). Note: Do not use the Barco internal patterns as the dots are not round.
(3g) For all 3 tubes, Do electronic center focus, then electronic zone focus.
After adjusting the tube magnetics, you may wan to recheck the optical focus & Scheimpflug again (see step 2)...
Positioning of raster using mechanical controls:
(4) Raster width coils: Turn all 3 all the way in. Adjust the two larger rasters to match the smallest in width at the center point. (Use the horizontal R/B shift pots to make it easier to line things up and measure the left to right horizontal centerline). One of the 3 coils must be turned all the way in! Note: Do not use a metallic screwdriver to adjust these coils. You'll fry the coil and possibly the surrounding area.
(5) Do a little bit of rough geometry work on green now while viewing a grid pattern: Set up a rectangle on screen that's pretty much the height and width of what you want. Set green raster shift to 49/49. If it's not centered when near 49/49 (midpoint), move the projector! You don't have it installed right! (Some minor offset from 49/49 is ok of course, but it probably shouldn't be more than 10 points away in any direction).
Set your R and B raster shifts to 49/49 (this is the center convergence zone for each tube respectively). Turn on R and B grids one at a time over the green grid and:
  • Use the horizontal shift pots to line up the R/B rasters to be even with the green (only look at the center of the screen).
  • Use vertical shift pots to line up R/B perfectly with green (only look at the center of the screen only).
  • Use vertical size pots to line up the top/bottom of R/B as close as possible with green (only look at the very top/bottom of the screen).
While some R/B raster shift may be used in subsequent steps or over time, your R/B rasters should both remain within a click or two from 49/49 (midpoint).
Now the 3 grids should be lined up as well as possible without using electronic controls (height, width, and positioning of the 3 grids should be the same). This ensure that we use a minimal amount of electronic compensation (important if you don't want it to drift).
Electronic controls:
(6) Now go through the guided setup and do the rest of the geometry and zone convergence. You'll skip a bunch of the early steps (raster centering, focus, etc) since they're already done. This is the simple part.
After that you have to set your brightness/contrast using test DVD's, then do greyscale, (recheck brightness/contrast after).
DONE!
This is a short list, as it's meant to only be a quick check guide. Each of the items in the list could easily be expanded into 1-2+ pages each... (no, I won't entertain doing this as it's very projector specific ). Some of the items on this list can easily take you 2-3 hours as well! The whole tube magnetics (section 3) stuff takes forever ...
Hope this helps someone!
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and HD DVD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
