Barco (Older Analog Projectors)
Layout and Setup Tips
(Page 2)
Page: 1 2
3 4
5 6
7 8
Back View
There’s a couple of important things to notice about the back of the analog
series of projectors. The first is, the RGB inputs are out of sequence as
labeled on the set. If you don’t hook the RGB cables up in the right order, your
picture will have very strange coloring.
Second, the older Barcos only had a composite sync input, so you have to use
a BNC ‘T’ combining adapter to feed separate H and V sync signals into these
sets, that’s not a big deal to do.
Most importantly however is the 15 pin ‘remote’ connector on the back of all
of the older analog sets. This remote plug in connects to either a wired remote
box that has the brightness, contrast, sharpness, input selection and color and
tint controls on it. The other option for this connector is to run a 15 pin
wiring harness to an RCVDS 4 Barco video switcher that also has these controls
right on the switcher.
The point is, a lot of these projectors are sold surplus without the
switchers or plug in remotes. The set will power up but no picture will be
displayed without anything connected to this 15 pin port. RCVDS switchers can be
found on eBay, but the plug in remotes are hard to find.
